You can change the collector without dropping the engine? I read somewhere it had to be dropped anyway to get at the rear collector joints...I found a guys site who takes it through step by step, not that I fancy doing it! Dads an engineer but works away and 'is too old to be grovelling under bikes now' so that leaves me.
I'm in Lincolnshire...probably a million miles away! I know of one or two more NC24s in Lincs - I saw some at a local bike meet and the guy said he's been doing one up as a project.
I can get an aftermarket collector from DSS for £130, there's a guy emailed me saying he can make one which doesnt need engine removal as its got slip-on joints for £250 or there's a set of f+r downpipes and collector on ebay at the minute
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT however the collector looks a bit mank but its only £65!
I know labour will be a bomb...a guy I know runs a bike shop/garage and he said hes not done one so wont quote on labour til i get the bits...bit reluctant to do that.
I have no idea what to do!
Took some photos today while still neglecting uni work - took some ColdStart to get her running and when I blipped the throttle all the condensation came out with a load of soot from the underneath so im pretty sure thats the source of the soot.
It may just be that my end can is clogged, but looks like the collector WILL need doing some time soon so Im in two minds whether to do it now while its winter and I can
actually get one!
Fancy working on a VFR project?! Lol :)
Tried to put photos up but could only do links, sorry...
http://i800.photobucket.com/albums/yy28 ... C03073.jpg
Lovely :)
http://i800.photobucket.com/albums/yy28 ... C03075.jpg
Full can...
http://i800.photobucket.com/albums/yy28 ... C03091.jpg
The source of the crud
http://i800.photobucket.com/albums/yy28 ... C03087.jpg
Bottom of collector...even if its not the problem me thinks it will need doing soon...
http://i800.photobucket.com/albums/yy28 ... C03083.jpg
http://i800.photobucket.com/albums/yy28 ... C03090.jpg
Condensation + throttle blipping + soot = murky soup! Forgot to move my manual etc so everything got covered!
List of other jobs to do:
Throttle cable lube and adjust
Choke cable lube and adjust or replace...seems to have no choke any more
Fairing plastics to repair and repaint (Plastex is on its way :) )
Good old clean and polish up!
Update:
Tried to look at the choke cable at both ends and encountered a slight problem in taking my airbox off...in addition to the seized swingarm bolts which resulted in snapped bolts, drilled out and then holes put in the swingarm ending in a swingarm replacement including my friend dropping the bike; a knackered exhaust; broken fairings etc; I discovered that whoever put the airbox in last crossthreaded one of the bolts so dad and I had to drill it out; plus the battery was nearly dry! This is the result...
not a lot left now!
plastics off...
one tired battery
We are assuming this is ok and doenst need replacing..
Bleeding bolts!
My two babies :)
