Page 1 of 2
Wanted 3TJ top (headlight) fairing
Posted: Wed Jan 06, 2010 7:57 pm
by plodder
Rough is OK. Local to Stockport is better. Cheap would be nice :whistle:
Ta :grin:
Re: Wanted 3TJ top (headlight) fairing
Posted: Wed Jan 06, 2010 8:30 pm
by Evilchicken0
Make a queue ... :o
Posted: Wed Jan 06, 2010 9:02 pm
by cagiva996
yep,behind me!!!! :lol:
Posted: Wed Jan 06, 2010 9:46 pm
by Evilchicken0
cagiva996 wrote:yep,behind me!!!! :lol:
You can borrow it on wednesdays
Posted: Thu Jan 07, 2010 10:05 am
by Taggyd
can i borrow it on fridays please! :grin:
Posted: Thu Jan 07, 2010 1:08 pm
by Evilchicken0
Only if you dance for it
Posted: Thu Jan 07, 2010 6:31 pm
by plodder
Boo!
I was wanting the option of running it on the road in the summer. I might just dremmel out a hole for the light out of a race fairing.
Posted: Fri Jan 08, 2010 9:50 am
by Evilchicken0
Do race fairings fit the standard subframe then ???
The lights are held on with the top fairing's bolts and if they're kept it might be an alternative
Posted: Fri Jan 08, 2010 11:10 am
by Taggyd
they do go over the standard frame, but just mount to the frame like the lower fairings and the mirror brace as they tend to be one piece top and sides so dont need the top mounting bracket most get cut cown to just the clock mounts though to keep things clear at the front. you could add fairing indicators rather than the sticky out ones and should be ok!
Posted: Fri Jan 08, 2010 1:05 pm
by Evilchicken0
I'd like to keep it mounted through the clocks (4 mounts) if possible - I was thinking about taking a mould and plastexing something together.
I'd probably change to indicator mirrors if I was going to all that trouble
