Wanted 3TJ top (headlight) fairing
Rough is OK. Local to Stockport is better. Cheap would be nice
Ta
Ta
Re: Wanted 3TJ top (headlight) fairing
Make a queue ...
- cagiva996
yep,behind me!!!!
You can borrow it on wednesdayscagiva996 wrote:yep,behind me!!!!
can i borrow it on fridays please!
Only if you dance for it
Boo!
I was wanting the option of running it on the road in the summer. I might just dremmel out a hole for the light out of a race fairing.
Do race fairings fit the standard subframe then ???
The lights are held on with the top fairing's bolts and if they're kept it might be an alternative
they do go over the standard frame, but just mount to the frame like the lower fairings and the mirror brace as they tend to be one piece top and sides so dont need the top mounting bracket most get cut cown to just the clock mounts though to keep things clear at the front. you could add fairing indicators rather than the sticky out ones and should be ok!
I'd like to keep it mounted through the clocks (4 mounts) if possible - I was thinking about taking a mould and plastexing something together.
I'd probably change to indicator mirrors if I was going to all that trouble
