Nc23 shock bolt
blueflag
Nc23 shock bolt
Post by blueflag »
Hi all,
I've just finished fitting my 600 shock supplied by GF, very nice too.
Taking off the old one was a nightmare though. The bolt on the linkage that goes through the swing arm was unbelievably tight coming out, might be something to do with it being bent by about 5mm!
Any ideas on how on earth that could happen?
Luckily I managed to clean up the tapped hole in the swing arm and the thread is ok.
I have a spare swing arm that came with the bike and the same bolt on that one is totally solid. Looks like I'll have to take it into work and drill it out. Very odd..... :o
justmartyn
Bike owned: Only 2 left.....
Re: Nc23 shock bolt
Post by justmartyn »
Before you do anything drastic, soak the bolt in WD40 or any other releasing oil for about a week, squirt a bit on every day. You'll maybe be surprised.
blueflag
Re: Nc23 shock bolt
Post by blueflag »
Tried WD for a bit, then heated it up with a blowtorch. Trouble is, the socket is deteriorating. I've already twisted one allen key :oops:
Whilst it's quiet in work I'll drill it out when I'm on nights.....
GF Racing
Re: Nc23 shock bolt
Post by GF Racing »
Real common problem this - seized Tri Arm rocker arm swinging arm bolt.
When we service Tri Arms - all suspension is removed and cleaned / regreased.
We use a half inch drive Snap on Air Impact gun with a short air tool spec allen socket to remove the offending bolt.
If that fails and it often does - simply change the swinging arm.
Have sold dozens of swinging arms over the years because of this - they are cheap enough.
Plus customers seem to then weigh in the old ally and recover the cost ...
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
