Fzr 2TK Questions
Fzr400rr 3tj Danny
- Bike owned: FZR400 1WG 2TK
Fzr 2TK Questions
Hey there, after my 3tj compression problems i finally went and got a new bike, i now have a FZR400 2TK =]
Just a few questions though;
What oil does it use/Whats best for it?
What are the carb settings for it?
Where can i get a manual for this?
And does any one know a decent website for parts?
Thank you very much =]
Danny
Danny
barryfzr
Re: Fzr 2TK Questions
The 2tk is more or less a 1wg genesis with a few tweaks..... they only made a few so I doubt if you'll get a manual in english for it. If you get one I'd love a copy ;o) I have a copy of the 1wg Genesis on pdf somewhere I think.
Si (http://www.madsi.co.uk/" onclick="window.open(this.href);return false;) has made a good site about his.
Fowlers in Bristol are probably the best for original parts if they are still made (you'll need your frame number or they get a bit narky). Most parts are identicle to the 1wg genesis so I sometimes give them that frame number instead and take the risk ;o)
Wemoto.com do a few pattern/ consumable parts as well and are pretty good.
Fzr400rr 3tj Danny
barryfzr wrote:The 2tk is more or less a 1wg genesis with a few tweaks..... they only made a few so I doubt if you'll get a manual in english for it. If you get one I'd love a copy ;o) I have a copy of the 1wg Genesis on pdf somewhere I think.
Okay, Cheers for that =] So would the genesis carbs fit? im guessing it could be cheaper to buy a new set then get this set refurbished? and also on that site is says 10W 50HD oil is that the correct oil or is that some sort of racing oil?
ALSO does the 3en1 parts fit like carbs etc?
Cheers for your help
Danny
The 2TK is actually the 1WG model SP (Sport Production) ... 1987 I think.
It was more like the 3en series than the Genesis having the EXUP an all.
Carbs from a 3en1 or 3en2 will fit and probably be about the right set up, yes it's far cheaper to fit these than get your reconditioned - you can always check the settings on the old carbs and see if they match the new ones.
Use 10/40 semi synthetic oil it will be fine for road use an remember oils have moved on since the time manual was written.
You can fit Yamaha Blue spot calipers to your forks I think ... just check the mounting bolt spacings are 100mm
Fzr400rr 3tj Danny
Okay thank you very much your a star, would you happen to know where i can get a manual?Evilchicken0 wrote:The 2TK is actually the 1WG model SP (Sport Production) ... 1987 I think.
Thanks again
Danny
One of the sticky threads has links to downloadble manuals on the web. If you can't find a specific one then use a 3en manual.
barryfzr
The exup bit on the 3en manual might help you for the exup bits, but I would get the 1wg genesis manual aswell for all the chassis, forks etc.
I have both the 1wg genesis and 2tk bikes
I think the manual is called the sac model strangely....if you have any problems drop us a line
Fzr400rr 3tj Danny
Okay thank you very much =] ill have a look for them now!
My new set of carbs should be here by thursday latest, luckily i got a brand new tool kit for crimbo :D
This is me and my bike
This jacket makes me look realllllllly fat, its just because it rolled up...
Shes a little bit dirty in these pictures, also it has new bolts in it insted of the manky ones you can see!
Shes got gamma 250 back end,
And front end too by the look of it ... none of the FZR's had upsidedown forks.
Ignor what I said about the brake calipers.
Fzr400rr 3tj Danny
Oh yeah iv only just noticed that lol.... Will the 3tj forks fit?
