remote reservoir mounting plate
I've recently purchased a non standard rear shock with remote. The bike its going on is an early nc30 without remote. Will the mounting plate from late spec nc30 standard rear shock do the job ?
- micpec
Re: remote reservoir mounting plate
well, I would say yes! That will do. And do not forget to check if the fluid line from the shock to remote fluid reservoir has enough length. Best to dry fit first.
Cheers... Anyone got one of these mounting plates hanging around ?
- Bike owned: RVF400 - ZX636
I have some at £5 delivered if you're in the uk.
Ok I'll have these off you, pm sent
Im after one as well if poss Geoff - im in the same situation.
