Improving the Mid Range on a CBR400 - any tips chaps! 8)
marty400
Post by marty400 »
hiya All,
RE:Improving the Mid Range on a CBR400 (NC29) - any tips chaps!
Not interested in top speed. But would like some more mid range grunt, easier overtaking, belting out of corners. Don't want to make my litte 400 a peaky so-and-so, un-ridable on the UK roads, just for the sake of chasing BHP etc...
Any tips guys?
Will changing the sprockets work on a cbr400 NC29, or will it play havoc with a mislieading Speedometer, and Mileometer?
Can someone confirm? (I'm getting some yes's and No's from another Non-bike specific forum!)
Slip on cans by themselves worthwhile?
Will dynojetting cause the bike to be more peaky?
(Any particualr cans work well with a CBR400??
Can I realistically get much more out of the 400cc, then the OE setup? (Not worth spending a fortune on meadocre improvements)
Hope you can advise!
Martin
LozVTR
Re: Improving the Mid Range on a CBR400 - any tips chaps! 8)
Post by LozVTR »
Changing the sprocket would be the cheaper + more effective option in my opinion.
Remind me - does the speedo run off the front wheel or the front sprocket nut on the NC29?
A bigger rear sprocket will cost you £25-£30 where as an exhaust will cost you alot more than that.
It depends what you want in the end. a quick fix or something that sounds good too.
Im picking up and NC23 on Sunday and im planning to do the following:
new chain and various size sprockets (taking it on trackdays so want some options)
Full exhaust system
Larger jets in the carbs
high performance filter
luckily ive got a couple of mates who have a dyno so im going to see if I can blag abit of dyno time too.
marty400
Post by marty400 »
Good luck with the bike on Sunday! hope she is a Blinder!
"Remind me - does the speedo run off the front wheel or the front sprocket nut on the NC29?"
*** no idea - I kinda was hoping someone could answer on this forum!
Where can I get a 14 teeth Sprocket for a NC29?
How much about?
Do I need match chain to sproket, or are the teeth on different makes of uniform dimensions?
Martin
binge
Post by binge »
NC29 speedo runs off the front sprocket nut so playing with sprockets will mess up the speedo. Which is un-accurate anyway so I wouldnt worry too much. :P
My bike has a 525 Heavy Duty chain.
And I am running the matching 525 Sprockets.
Some bikes run 520 chain/sprockets, And some bikes run 530 chain/sprockets.
Its just the size of the chain, it will probably be stamped one very other chain link anyway.
An end can wont do a great deal to the running of the bike, My NC30 wouldnt wheelie too great with the stock system, when I put a straight through end can on it, It was easier to wheelie, but that was about it.
Is your NC29 restricted?
Ben
marty400
Post by marty400 »
Ben
Hiya Ben,
Um... how do I tell? Is there any way - besides going illegal speeds? (I think we hit 110mph on the Motorway, when we were trying her out!)
Martin
PS:
Are there any other small mods I can do to improve mid range??
leopard_pagan
Bike owned: used to have a NC29
Post by leopard_pagan »
on a quiet PRIVATE road, see if the NC29 will pass 112mph.
if it does= speed restrictor has already been by-passed.
if it gets to 112mph then feels like it cannea go ana fasta captn....... its still speed restricted.
tanuki
Post by tanuki »
I am afraid its an in line 4 engine and they make most of their power high up in the rev range, messing around with sprockets wont improve the mid range power and by going for a larger sprocket on the back and or a smaller on the front will only make the bike accelerate faster but will make the bike more peaky up top.
you can get a decent can and spend a bit of cash getting it set up properly on a dyno which will gain you more power through the range but thats about all.
Your other choice is...well a V4 LOL IMHO the perfect road engine where as I love my CBR for the track.
Mikiboy
Bike owned: RVF400 NC23 x 2 NC29 CBR4/600
Post by Mikiboy »
It wont improve the midrange but you effectively slightly shorten each gear giving the impression it has as it will rev through quicker.
Graheme france for sprocket.
Dont bother with the rear as you may have to add another link to the chain
little nick
Post by little nick »
Definately go down to a 14 tooth front sprocket - it'll make it much more useable in the 'mid range'
Otherwise - it's dyno time. Any decent dyno operator will be able to smooth out & improve the power delivery.
To support dyno time - it's all down to money - how much do you want to spend? All the bolt on bits cost - but they all benefit from correct set up on the dyno.
Pick a maximum cost - budget for the dyno time, spend the rest on free flowing bits!
marty400
Post by marty400 »
little nick wrote:Definately go down to a 14 tooth front sprocket - it'll make it much more useable in the 'mid range'
Cheers Nick!
Martin :D
