Showa rear shock
Burbage
Showa rear shock
Post by Burbage »
I have just acquired an adjustable Showa rear shock for the NC30. Anyone know how to get the spring off it?
Re: Showa rear shock
You need a spring compressor or some brute force and ratchet straps....
it can be done, but I'd take it to someone welse and get them to do it if I didn't have the tools
+1 on that ^. without the right tools your end up throwing it out the garage after smashing your knuckles to bits
Burbage
Post by Burbage »
Thanks for the reply, I have now got the spring off it, no dramas, just needed a bit of care :grin: .
I thought it had adjustable damping but no, it has a remote adjuster for the preload on the spring, anyone had any experience of one of these? Are they reliable, I do not want to find the preload sagging after a week!
The bad news is the damper is knackered, who's best for showa damper rebuilds?
I am guessing it is a VFR suspension unit, the only id. on it is "MLO 003", does that mean anything to anyone?
Burbage wrote:Thanks for the reply, I have now got the spring off it, no dramas, just needed a bit of care :grin: .
It does ;)
It's for a VFR400R NC21/NC24
ML0 is the honda PCN for the NC21/24 VFR400R
http://www.vsource.org/VFR-RVF_files/BHondaPCNs.htm" onclick="window.open(this.href);return false;
List of PCN's there if you want to know different PCN's :)
NC30 specific stuff is MR8
http://cgi.ebay.co.uk/Honda-NC24-NC-24- ... 5ad1d648ca" onclick="window.open(this.href);return false;
Same as that yea?
It's a decent shock, the preload adjustment works well.
Burbage
Post by Burbage »
Neosophist wrote:It does
http://cgi.ebay.co.uk/Honda-NC24-NC-24-" onclick="window.open(this.href);return false; ... 5ad1d648ca
Same as that yea?
Thanks for the reply. Yes it is one of those and I paid alot less :P
I am now not too sure what to do with it, I like the idea of the remote preload adjustment, I might try to adapt it to fit the standard shock.
Same as that yea?
A lot of the VFR750/800's use a very similar shock... as per the one below.
http://cgi.ebay.co.uk/Honda-VFR800-adju ... 5d26bd9bad" onclick="window.open(this.href);return false;
(even same adjuster handle :P)
Anyway.
It should just bolt in? try it? :)
