Caliper seals
buzzawak
Caliper seals
The feel on my front brake lever is rock hard so I guess the seals have lost there rebound and need replacing.
I am looking for a cheap source for the seals kit as I have the 4 piston type. Here in Australia Yamaha wants $43 per seal kit. Each kit has 4 seals so I am told that I have to buy 4 kits to do both calipers. Grand total of $173. A bit rich if you ask me. Anyone know a good source ?
Re: Caliper seals
Which calipers have you got ???
If they're the original silver ones then you may as well replace them completely with the later "Blue Spot" type which are fitted onn just about all modern non-radial Yamahas. You might find them slightly cheaper by searching for a less popular model like a Fazer but they'll be similar to the R6 etc. One thing to know is tey have 32 / 34 or 34 / 34mm pistons you only really need the 32/34s but the others are ok too.
- Motorcycle Solutions
Re: Caliper seals
GOTO http://WWW.WEMOTO.COM" onclick="window.open(this.href);return false;
buzzawak
Re: Caliper seals
Gold 4 piston ones.Evilchicken0 wrote:Which calipers have you got ???
Re: Caliper seals
They're the standard ones for the bike - The money for new seals would be better going towards replacing them.Gold 4 piston ones.
buzzawak
Re: Caliper seals
Hi Lajracing, Wemoto are only listing the piston and seal kit not the seals by them selfslajracing wrote:GOTO http://WWW.WEMOTO.COM" onclick="window.open(this.href);return false;
buzzawak
Re: Caliper seals
Hi Evil, Yes just tosing around the idea of doing the R6 caliper swap. Once again it would be the case of getting them from the USA. Nothing is listed on Ebay aust and the wreckers here would want some stupid amount.Evilchicken0 wrote:They're the standard ones for the bike - The money for new seals would be better going towards replacing them.Gold 4 piston ones.
Re: Caliper seals
Don't they hve any modern Yamaha's over there or do they just not advertise through e-bay
buzzawak
Re: Caliper seals
I just did a ebay aust search and not one r6 caliper to be seen. The bike wrecker here over charge for their parts. I think they don't want to compete on eBay.Evilchicken0 wrote:Don't they have any modern Yamaha's over there or do they just not advertise through e-bay
Anyway last night (3am in the morning) I won two auctions the first for a complete front brake setup off a 04 r6 including the right clipon and controls and the second auction for the left clip on and controls. Total cost including postage from the US $145.00
So I am happy for the moment.
Question: What is the diameter of the 04 r6 fork?
Re: Caliper seals
Depends on the year but in either case ... bigger than the 3en1's ... I think the Right way up forks are 43mm.
But the bar will be 22mm (industry standard) so the master cylinder should fit. not sure if the brake lines will be be the right length though.
