Changing front sprocket
Posted: Mon Nov 16, 2009 7:03 pm
by myheroduane
hi all i have recieved my 14t front sprocket for my nc30 and i am just wondering before i jump into the job what is accually involved removing chain/adjusting chain ect.? any input would be nice, cheers
dave :ninja:
Re: Changing front sprocket
Posted: Mon Nov 16, 2009 7:08 pm
by royster81
i swapped out a 15t for a 14t recently and all i did was loosen the 17mm pinch bolt and slacken the rear hub until the chain was fully lossened , removed the front sprocket cover,undid the 14mm nut ,pulled the chain off the sprocket and removed it.
instalation was the reverse.
Posted: Mon Nov 16, 2009 7:09 pm
by Drunkn Munky
Remove bottom fairing
Remove sprocket cover
Sit on bike with right foot on the brake, socket and wrench on the sprocket bolt and give it a good tug.
Remove bolt
Slacken off the chain
Remove sprocket and replace with new 14T
Reassemble
job done :grin:
Posted: Mon Nov 16, 2009 8:19 pm
by myheroduane
will i need a special chain tentionor tool?
Posted: Mon Nov 16, 2009 9:47 pm
by bradders
You can get away with using a long flathead screwdriver as a drift and knocking the hub round with a hammer, it's what I use until I buy the tool :peace:
Posted: Mon Nov 16, 2009 10:08 pm
by Drunkn Munky
Just be carefully you don't mash the teeth on the hub if using the hammer and screwdriver method
Posted: Mon Nov 16, 2009 10:10 pm
by royster81
just buy the tool, it's only £16 quid and it beats the £60+ you'll have to pay when the screwdriver messes up the teeth on the adjuster.
