sp rear wheel in rr?
nick
Had a look around the threads, but i find the search function on this site a little frustrating so i've given up looking
Anyway, can you use the 3tj sp rear wheel in the 3tj rr?
I'm sure i've spotted somewhere, something about the captive spacer/caliper hanger. The sp wheel has the captive spacer, and as yet i've not bothered to see if it fits, so can anyone let me know what, if anything, i need to do in order for it to fit?
Cheers,
Nick
Cheers,
Nick
bendy3
- Bike owned: FZR400RRSP FZR400 HYBRID RRSP
Re: sp rear wheel in rr?
The differance is the rear caliper hanger, the sp one has a captive spacer. I have used sp wheels in rr swingarms but use an m20 washer aswell as the wheel spacer.
nick
Sorry, blonde moment approaching.......m20?bendy3 wrote:..........use an m20 washer aswell as the wheel spacer.
hunter
(sounds like washer with 20mm hole to make up the gap the washer being the same dia as the wheel spindle 20mm.
nick
that's what i thought, but i wonder what thickness it needs to be?
bendy3
Std m20 washer is about 2.5-3mm thick
nick
Sorry to dig this up again, but how many of the m20 washers do i need?
bendy3
just 1
You can find them on the road to Brands Hatch
mick c
or you could get the correct sp chassis, swingarm, caliper mount etc? makes wheel changes a pleasure and not a chore!
funnily enough i may just have what you need..
