Electrical Problem On NC29
- Bike owned: cbr400rr nc29 , 90 GSXR400SP
I installed a used Wiring harness on my NC29 now when i start the bike.. it burns the starter replay fuse after 5 minutes of use... What can be the problem?
Also anyone know where can i find rebuild kit for my carbs? the left one leaks from the bowl...
thank you...
thank you...
Re: Electrical Problem On NC29
trouble with used parts are that you dont know how long they will last, or in some cases, if they will even work.
what you are going to have to do is check the loom closely for broken wires, wires shorting with other wires, burnt wires, corroded wires. check the fuses, check all earth points. bad earth cause lots of problems.
you will need to clean anything you find, you may need to cut off the bad and re-crimp the connections back on. re-wrap the harness.
a headache of a job..
