has anyone ever heard of or done this
nc30 madness
Post by nc30 madness »
hey hey ;)
has anyone ever heard of putting an nc24 engine in an nc30 frame with nc30 carbs
i heard guys that race on track do this because the nc24 has a shorter 1st gear
does the nc24 engine have better performance over the nc30 engine?
would like to read your guys comments
Cammo
Re: has anyone ever heard of or done this
Post by Cammo »
Not heard that before, and I don't think that the 24 engine goes easily into the 30 frame.
You don't want a lower gearbox for racing, you want a closer ratio gearbox (nc30).
Usual racer combo is a 35 engine with a 30 gearbox. Carbs are up the individual, 30 carbs will make higher top end hp, 35 carbs are much easier to setup and will be near identical in club racing.
No - you'll be thinking NC35 engine which is pretty much the same animal and is an easy fit.
The NC24 is a 400cc V4 but has a 180 degree crank for starters
CMSMJ1 wrote:No - you'll be thinking NC35 engine which is pretty much the same animal and is an easy fit.
It's still an NC13 Engine though so I doubt the mounting points are that different ;)
I'd prefer the 30 frame over the 24's though given the choice.
The NC35 has a different mounting points as the frame was changed to alter balance.
If anyones got a picture of an NC30 engine i'll measure the mounting points on an NC24 engine as they 'look' like there in the same place as the 30 engine ;)
fastdruid
Regular Member
Post by fastdruid »
The difference fwiw between the 180 and 360 crank is the 180 is smoother, the 360 or 'big bang' gives very slightly more power[1] but more to the point it gives the tyre more time to recover in between power pulses.
Druid
[1] As in 2hp out of the 750...
fastdruid
Regular Member
Post by fastdruid »
Neosophist wrote:If anyones got a picture of an NC30 engine i'll measure the mounting points on an NC24 engine as they 'look' like there in the same place as the 30 engine ;)
Well there is this one
from http://www.400greybike.info/newforum/vi ... 62&t=11723" onclick="window.open(this.href);return false;
Druid
CRM
Admin NWAA
Admin NWAA
Post by CRM »
lol, looks v familair. someone's nicked the bike from around it
Apart from the mounting hole by cylinder 3 there isn't much difference. Shouldn't be too hard to fit the engine in :)
The 180 firing order also seems to run cooler (only 1 rad needed) both bikes produced 60bhp too so *shrug* :)
Cammo
Post by Cammo »
The nc24 rear exhaust headers might not fit into the 30 frame very easily, hard to tell.
Stickshift wrote:The nc24 rear exhaust headers might not fit into the 30 frame very easily, hard to tell.
If your putting it in a 30 frame use the 30 exhaust ;)
