Wheels, cush drives and sprocket holders...
Hi all,
Am moonlighting in the yammy section as I have an FZR600 3he trackbike and a 1wg frame to rtansplant the kit into it....anyways...I am was going to fit one of my spare wheels to the 600 for a sneakly TD at Angelesy in 2 weeks but when I whipped the rim off I see the cush drive and sprocket holder are not compatible.
I want to know - can I get an FZR400 sprocket holder to take the 600 sprocket and fit to one of my spare wheels?
See the pics - yellow on is the 18*3.5 rim and the black and white rims are spare 400 rims with intact cush drive ubbers but no sprocket holders. Can it be done? or am I pissing in the wind?
http://i100.photobucket.com/albums/m38/ ... CF2160.jpg
http://i100.photobucket.com/albums/m38/ ... CF2159.jpg
http://i100.photobucket.com/albums/m38/ ... CF2158.jpg
When I build my 1wg - http://i100.photobucket.com/albums/m38/ ... CF2135.jpg
can I fit one of the spare wheels to fit?
Thanks all, don't tell the Honda crew I am down here....they will lynch me!!
MARK
MARK
Re: Wheels, cush drives and sprocket holders...
As you've got the 400 and the 600 sproket carriers you can probably check it quite easily. I think the 600 sprokets will fit but I don't want to say for sure.
The 600 wheels will fit the 400 swingarm but you need the brake carrier and I think the calipers are slightly different.
The 400 is a 1987 3EN1 EXUP by the way.
Cheers Boris,
I do not have the 400 sprocket carrier. That one is from the 600.
I will get onto the ebya session and see if I can source one. If not, no worries as I will use the 600 with the skinny tyres for now and kill them off and my TD.
Thanks also for the model info - 3EN1 is 2 lights and two tubes below the lights? I think it will be great when I finally get it sorted out.
I intend to use the white wheels I have for the build so will source a 400 sprocket carrier asap to check it all out.
2 lights and air intakes above you can probably fit the 600 fairing if your lucky
cheers Evil..
I don't have any bodywork for the bike - it was dressed as a flying banana with pretend R6 bodywork. It is a shed at the minute but will be reborn
I know you have the info - so any ideas what shocks might fit as the braced swingarm looks prohibitive for any none remote res later model shocks??
would the 3he shock fit for now?
cheers
cheers
hmmm ... maybe !!!
only know the 3TJ shock is a long bugger !!! Get the shock out and measure it then have a look around ... I remember a YZF750 shock was about right but not sure whick model it was fitted to
				Taggyd
i think ive got a 3en1 sprocket carrier lurking in the shed, the sprocket is nackered though! let me know if you're interested.
						- Motorcycle Solutions
r6 shock 06 - 08 will fit along with oollits special little spacer for the bottom of the shock and they are excellent..
Yes please mate.Taggy wrote:i think ive got a 3en1 sprocket carrier lurking in the shed, the sprocket is nackered though! let me know if you're interested.
PM sent
				Taggyd
