help needed - headlight relay?
Posted: Sun Oct 11, 2009 11:17 pm
Hi, can anyone help please.
When I turn the ignition on on my RVF 400 the headlight no longer comes on. I've checked fuses etc and all other light are on apart from the headlights (low and high beam). I presume it's the headlight relay as i can get the lights to come on if i remove the relay and bridge it with wire. Problem is, the local parts dealer doesn't have a clue which relay to order to replace the original! So can anyone point me in the right direction where I can get this replacement 4 pin relay from. If it helps the old one is 'MATSUSHITA CA1A-dc12V-CACA 1218-1'....
Paul
+psypher+
Paul
+psypher+
