Engine cover.
Martinh
Engine cover.
Post by Martinh »
Had a bit of a crash the other week caused by some minor ground clearance issues with the exhaust.
I've unfortunately managed to crack the starter clutch engine cover (1wg-kidney shaped cover)
If anyone has one going spare I'd definitely be interested!
Also can anyone confirm if it is the same cover as the one used for the generator on 3tj's and thundercats?
thanks very much
martin.
tiptop
Re: Engine cover.
Post by tiptop »
try ebay thers normaly always someone breaking one on ther
smemly
Bike owned: FZR400RR 600 Hybrid
Re: Engine cover.
Post by smemly »
Hi Martin,
I've got a spare 600 Foxeye one in my garage, looks slightly different on the outside to the 400 but it definately fits, ran it on my 3TJ before i done the engine swap. From memory it is in pretty good condition, might be a little dusty as it has sat on a shelf for the last year or so.
I'll get a picture of it when i get in later. £20.00 inc postage?
Lee.
Re: Engine cover.
Post by Evilchicken0 »
The generator covers are different on the 3TJ and T'Cat and Foxeye are different again.
I think the FZR600 covers are similar though.
Martinh
Re: Engine cover.
Post by Martinh »
Ok, it appears i may have got a little confused.
I am definately after a starter clutch cover. I thought the generator cover on 3tj's was the same as the starter clutch cover on 1wg's. (something i saw on bdk's website threw me). thanks evil.
Right then, cheers lee, if what you've got is the starter clutch cover then 20 quid sounds great. I guess if you could pm me with how you'd like me to pay we're in business.
cheers
martin.
smemly
Re: Engine cover.
Post by smemly »
just to confirm and make double sure etc
This one:
As you can see it is a slightly different finish to the 400 ones but mine fitted ok through the fairing gap on the 3TJ, so should be ok for the 1wg.
