Common problems with VFR 400
Dimple
- Bike owned: Honda vfr 400 NC 30
I am based in South Africa and it is such a mission to get any race kist for this bike. I see some wicked bikes on this site. Can i maybe get some suggestions on what kits will fit on the VFR 400. Also is there any thing i need to watch out for that is common on these bikes.
- Sligeach
Re: Common problems with VFR 400
what do you mean bro by what kits fit?
body kits like plastics? fairings?
Dimple
Yes body kits from other bikes
DanHam
http://www.tyga-performance.com/site/index.php" onclick="window.open(this.href);return false;
http://www.jap4performance.com/" onclick="window.open(this.href);return false;
http://www.k-conversions.co.uk/" onclick="window.open(this.href);return false;
personally I would go for one of the top 2 before K conversions. I have a TYGA kit myself, I never fitted it, their parts are very good.
Dimple
Thanks will have to try and import it to SA
- Sligeach
there are not any fairings that bolt-on directly to the VFR400, you can get the lowers from a RVF400 to bolt-on directly but thats the only thing that can be taken off any other bike and stuck straight on without any modification.
as the lads have pointed out Tyga and K conversions do kits that are designed for the VFR400 and bol-on after you drill out some of the holes.
do you wanna update the look of the bike or just get new fairings that look nice and shiney and new?
crofty7
Dimple - from my limited experience but somewhat bad luck with mine i advise to look at the following:
Check the clutch (paddock stand required) stick it in gear and try and move the back wheel around, it should be near on impossible to move.
Check the fork seals and that the front and rear shocks do not "bottom out"
Check the brake pads and lines
Check the electrics look in good order and not butchered
Check the fan is working so the bike doesn't overheat
Check bearings in the wheels and head stock
Once you get the bike then give it a good service i.e. flush and clean the coolant system, put new coolant in, new plugs, oil filter, oil, change the fork seals, dust seals and replace the fork oil, Check the valve clearances and reset to correct clearances if required, Clean the carbs and have them balanced and depending on the the state of the hoses replace them with braided items with fresh fluid.
Dimple
Thanks for all the advice.
Dodgy Roj
- Bike owned: too many to list
All the things i wanted to know too have just been answered cheers all.
mikhailmuller
howsit guys im new on the biker scene just recently bought a 400 vfr. when riding the bike if i stop at robots it does not want to idle properly it keeps on swithcing off, is that something i should be worried about or am i just not riding it corrctly lol
