WANTEd FZR400RR 3TJ Restriction Kit
pearson*
Bike owned: FZR400RR
Post by pearson* »
Hi,
just recently brought my fizzer but sadly it needs restricting :(
does anyone have one/know where i can get one cheap as i dont want to pay 250 to buy one from fi.
thanks
buzzawak
Re: WANTEd FZR400RR 3TJ Restriction Kit
Post by buzzawak »
We probably do things differently here in Australia, but don't you have to have the restriction noted on your registration.
If so and you stick them in yourself how do you prove it to your transit authority?
joshua102
Bike owned: Gsx-R600K9 3tj NC35
Post by joshua102 »
I have a spare set of 33bhp restrictor washers £35 including p&p,PM me if you're interested.Josh
pearson*
Post by pearson* »
Thanks, Pm'd now :grin:
sportspromatt
Post by sportspromatt »
where exactly are these bikes restricted, The jap RRSP that i have will rev, when stationery, but wont go past think it is 10k revs when riding!
I had a look at the carbs, that are flatsides, but didnt see anything unusual
I thought it was restricted in either the rev counter, or the (ECU) ?
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Post by Taggyd »
there is a speed restriction (180 kph) but also the revs are limitted in the ecu i think to about 14k, so 10k is a bit wierd, maybe its not jetted right?
Post by Evilchicken0 »
Check the wiring behind the speedo - if it's been butcherred or the speedo doesn't work the cdi will restrict the bike to 12,500 in all gears
