fzr400 3tj firing order? is it 1234 starting from the left?
rickyr
fzr400 3tj firing order? is it 1234 starting from the left side when sitting on bike or am i wrong?
fzrtim
- Bike owned: FZR400 FZRhybrid FZR600 RSV1k
Re: fzr400 3tj firing order? is it 1234 starting from the left?
Firing order is 1-2-4-3, 1 been the left cylinder when you are sitting on it!
I though it was 1 3 2 4 oh well never mind
hunter
it's 1342 from left to right,siting on the bike.
rickyr
thanks for the replys
i can get all caps on at 1243 but the bike dosnt run all that good number 3 will not gon onto the 2nd cyclinder from the left as its not long enough i thought maby i had the coils on the wrong way but if i reverse them then number 1 will not go on 2 the 1st cyclinder from the left side.
number 3 must go onto the 3rd or 4th cyclinders the other i dont no lol the best way the bike has run is 1234 but it didnt seem 2 want 2 rev over 8k this could be becasue of a few other things tho.
any one have a manuel they could check???
hunter
The plug leads are numbered,and fit in order,No 1 left cyl.
No 2 2nd cyl
No 3 3rd cyl
No 4 outside right cyl.
No 2 2nd cyl
No 3 3rd cyl
ARn13
Check out service manual downloads chapter 2 page 28, shows you a full diagram of coils and ht leads set up. wud paste it here but cant figure out how to
. Its on general section http://www.commline.com/FZR/400/MANUAL/" onclick="window.open(this.href);return false;
rickyr
i think thats for the older model but if its the same they mine is slightly different set up on that the number 3 is on the left side coil and the inside my number 3 is on the right side coil and is the out side of the 2
when i put them 1243 the bike is hard 2 start and when started runs awful when i put them 1234 the bike starts easy and runs alot better
Oh ... god this really isn't a post for dyslexic's
There are 2 coils
Each coils fires Twice per revolution at top and Bottom (the bottom spark has nothing to ignite).
One coil works cylinders 1 and 4 (the outside ones)
The other coil works cylinders 2 and 3 (the middle ones)
As long as they're wired with the middles to one coil and the outers to the other it will either run or not.
Sounds like you've got a dodgy connection, probably with the plug cap. Unscrew them one by one cut the HT lead back by 5mm and screw the cap back on.
There are 2 coils
rickyr
Evilchicken0 wrote:Oh ... god this really isn't a post for dyslexic's
There are 2 coils
aye and thats the way i have it it works out at 1234 starting from the left side but i just asked make sure then people said it was 1243 and a few other ways etc...so then i was confused lol
aye il cut about 5mm of each of them for a new conection
