how do you check valves when you are running total loss
Posted: Wed Sep 02, 2009 7:50 pm
HI there
I am currently rebuilding my nc23 engine after an off at anglesey which resulted in a broken selector barrel. I have fitted the new part no probs, just before putting crank cases together i decided to check crank and rods etc for wear or damage. This is where i forgot it has gear driven cams and not chain driven, as i rotated the crank it popped up out of the upper crank case halves. I managed to jostle it and get it back into position. This is where it dawned on me that it may have skipped a tooth and now be meshing in a different position than it should! which i presume will alter the valve timing relative to the crank. I decided to check valve clearences for peace of mind, but my bike is running total loss and has had the alternator rotor removed, but the rotor has the marks on to determin the position of the crank to enable you to check valve clearences. Will i have to buy a alternator rotor and put it on just so i can check the valve clearences or is there a dodge. I presume this is a common problem when checking valve clearences on total loss race bikes?
I would be grateful for any help given. Oh also does anyone no if an nc29 alternator rotor is same as nc23
cheers Rigs
cheers Rigs
