RVF400 forks
Posted: Mon Aug 17, 2009 9:28 pm
by brido
Hi there can someone tell me if rvf400 forks fit into vfr400 yokes without any modifications or if there is any modifications, what they are? Also is there any advantages from fitting rvf400 forks as opposed to the standard vfr400 forks?
cheers....
Re: RVF400 forks
Posted: Mon Aug 17, 2009 9:37 pm
by abrmoto
Oow you are going to get it from some of the funny folk on here................................
Use the search box at top of page, ssshhh I did not tell you
Re: RVF400 forks
Posted: Mon Aug 17, 2009 10:01 pm
lol.
No - they are obviously different.
The internals are the same.
hows that?
Re: RVF400 forks
Posted: Mon Aug 17, 2009 10:36 pm
by royster81
brido wrote:Hi there can someone tell me if rvf400 forks fit into vfr400 yokes without any modifications or if there is any modifications, what they are?....
you'll need rvf forks (funny enough) rvf yokes, clip ons,calipers, lines ,mud guard ,spindle, spacers,rvf-nc30 fitting kit ( off rick oliver) .so no unless you have deep pockets
brido wrote: Also is there any advantages from fitting rvf400 forks as opposed to the standard vfr400 forks?
cheers....
they look good, erm ...are a bit firmer ....er ..erm ..you can adjust them a bit more ???
fwiw get rick olvers fork spring kit into your front end and it'll be right !
Re: RVF400 forks
Posted: Tue Aug 18, 2009 11:44 am
by Martin
The most important difference and one that will see most gains is that they're.......
Gold
