Engine mounting and spacer help pls NC30
Posted: Sun Aug 16, 2009 7:17 pm
Ok guys, just put the new frame over the engine, and the bottom long bolt is in and through and a bolt at the front just to keep it level.
now there were a load of spacers came out when i lifted the frame off the engine. but cant for the life of me remember which bolt / spacer to where.
the castelated nuts at the bottom i presume these go just about finger tight when the main long bolt is all the way through / home before i stick the luck nut on the left hand side ?
i have used the larger of the 2 spacers on the left underside (nr choke) and the thinner on the right, and this seems to be about right.
no idea on the fronts though
Any one help or advise on this ? is it critical or best guess / and space the motor so it sits to the left / right more ?
