NEw game, "Name that swingarm"
Anyone know what bike this swingarm belongs?
- Bike owned: Cbr1000rr,Nc35,3TJ & Rg500
Re: NEw game, "Name that swingarm"
a honda triarm swingarm?
- Sligeach
Standard 3en1?????
cheers
Ian
cheers
Ian
i agree with ian it looks like a 3en1
I thought these were aftermarket,got one on mine.
Problem is I got a r6 shock off ebay but these isn't the room because of the bracing, bummer
Should i be looking for a 3en2 swing arm?
Is the 3en2 a straight swap?
Should I be looking for a shock with a remote reserve?
Is the 3en1 a better swing arm because of the bracing (i am not worried about the weight difference)?
oops just posted on your other post ........ last time I measured them all the 1wg arms will go in...(never assembled a complete rear end though) a 3tj arm would go in too ...but would need bushes made for the pivot point
Ok, after much measuring I have concluded that you cant fit a r6 shock on the 3en1 without major modification to the frame or swing arm
. So its either replace the swing arm or look for a shock with a remote reserve. Bummer I do like the r6 shock. Seeing that the 3en2 is a straight swap I think I will go down that path.
Did you get my PM ?
