petrol drip drip drip
Posted: Thu Aug 06, 2009 10:42 am
by dickydoon
he folks,when my rvf is on the sidestand and i fire her up for the first minute of idleing i get a drip of petrol onto the floor only about 5 tablespoons,but i cant for the life of me see where its coming from,not had the plastics off yet but been under and over it with torch and cant seem to locate it,its defo not the fuel tap any ideas or info will help
Re: petrol drip drip drip
Posted: Thu Aug 06, 2009 11:27 am
by Sligeach
is it definatly petrol? it could be condensation from inside the exhaust.
Posted: Thu Aug 06, 2009 11:35 am
by viper_biker
You could be over-filling that tank and the fuel is coming out the overflow pipe, failing that, a Sligeach says, it might well be water from the exhaust. However, could have a cracked float bowl. have you noticed and difference in performance?
Posted: Sat Aug 08, 2009 2:23 am
dickydoon wrote:he folks,when my rvf is on the sidestand and i fire her up for the first minute of idleing i get a drip of petrol onto the floor only about 5 tablespoons,but i cant for the life of me see where its coming from,not had the plastics off yet but been under and over it with torch and cant seem to locate it,its defo not the fuel tap any ideas or info will help
Move the bike and light it (carefully) if it doesn't burst into flame it isn't petrol.
I get a drip of condensation out of the exhuast for a minute or two when its first fired up.
Posted: Sat Aug 08, 2009 8:49 am
by dickydoon
na defo petrol,no differace in preformance,could it be a slight split in hose,and when warm the hose expands and stops the leak??dunno
Posted: Sat Aug 08, 2009 1:08 pm
by banoffee
definitely worth taking the belly and sides off for a closer look
Posted: Sun Aug 09, 2009 9:37 pm
Not good, could be a leaking fuel tap or anything really. I'd get it sorted though before the bike catches flames.
Best thing to do it wrap toilet paper around the petrol tap, around the carbs and anywhere else, next day see which are wet :)
Petrol tends to run so if you dont have rags around parts you might be tracing the tail end of a leak.
