Tail piece removal
Posted: Tue Jul 28, 2009 10:43 am
by caf237
Hi, i have a GK76A. i want to replace the tail lights. How do i remove the pillion seat. There is a lock at the bottom but it is busted. is there any other way i will be able to get in there to do the replacement?
Re: Tail piece removal
Posted: Wed Jul 29, 2009 6:36 pm
by mattley87
not really, how is the lock busted?
where in the country are you?
Posted: Wed Jul 29, 2009 11:07 pm
by white_hendrix
You might have to drill through the lock, get a diamond tipped bit if you can, it'll save you a lot of time and won't razz the tool first time you use it!
Posted: Thu Jul 30, 2009 7:19 pm
by mattley87
You could do that, or you could use the right tool to take the lock off, but the likeliness is that the cable has broken so it's possible that this may not work.
Posted: Sat Aug 01, 2009 9:42 am
by M1KE
Unbolt the lock and pull on the cable that should realease your seat.
Posted: Sat Aug 01, 2009 12:20 pm
by mattley87
as easy as that apart from the theft proof bolts that usually get covered in road grime and seize on the bike.
Posted: Sun Aug 02, 2009 9:22 am
by M1KE
thats why you drill them out.
Posted: Sun Aug 02, 2009 12:50 pm
by mattley87
As a last resort yeah but there are several other ways of doing it before drilling.
Posted: Tue Aug 04, 2009 8:30 pm
by Jaicen
Just take a hacksaw to the end of the cable outer, and pull the cable. KISS
