Tail piece removal
caf237
Tail piece removal
Post by caf237 »
Hi, i have a GK76A. i want to replace the tail lights. How do i remove the pillion seat. There is a lock at the bottom but it is busted. is there any other way i will be able to get in there to do the replacement?
mattley87
Re: Tail piece removal
Post by mattley87 »
not really, how is the lock busted?
where in the country are you?
white_hendrix
Bike owned: GSXR400
Post by white_hendrix »
You might have to drill through the lock, get a diamond tipped bit if you can, it'll save you a lot of time and won't razz the tool first time you use it!
mattley87
Post by mattley87 »
You could do that, or you could use the right tool to take the lock off, but the likeliness is that the cable has broken so it's possible that this may not work.
M1KE
Post by M1KE »
Unbolt the lock and pull on the cable that should realease your seat.
mattley87
Post by mattley87 »
as easy as that apart from the theft proof bolts that usually get covered in road grime and seize on the bike.
M1KE
Post by M1KE »
thats why you drill them out.
mattley87
Post by mattley87 »
As a last resort yeah but there are several other ways of doing it before drilling.
Jaicen
Bike owned: GK76SP & ER6F
Post by Jaicen »
Just take a hacksaw to the end of the cable outer, and pull the cable. KISS
