Pinch bolt torque settings
- Julesholling
- Bike owned: Honda VFR400 NC30
Does anyone know what the torque settings should be on the rear wheel pinch bolt?
Mine is stuck solid at the moment
and was going to get a torque wrench to help get the thing off as my normal short socket set just won't do it at the moment
Re: Pinch bolt torque settings
Honda Genuine Manual states that the Rear Hub Pinch bolt, if that is what you are referring to, should be Torqued up to 165nm. So it will take some leverage to get it on and off correctly. (Although you only need to loosen it, not remove it)
As for the Rear Wheel Nut, that should be 120nm so again, some good leverage will be required.
As for leverage, DO NOT USE A TORQUE WRENCH TO UNDO NUTS AND BOLTS!!! You will end up damaging the Torque mechanism and the thing wont work! Even if you think you havent damaged it, you could still of done in such a fashion that the Torque readings it gives out will be innaccurate and cannot be trusted!!
You should use a standard Narrow handled Wrench and then put a bar or long metal pipe over the handle for extra leverage!
165 is for the 46mm hub nut
120? for the wheel nut itself
think it is 55 for the actual pinch bolt.... not 165, you'll strip it
EDIT - just checked..I am right..lol
Depends which bolt you want!
and as Hamster says, don't knacker your torque wrench undoing stuff with it. get a bar on the small socket.
- mattUKNC
I thought the pinch bolt was around 60ft-lbs myself.
- Julesholling
Great guys, thanks for that.
Think i'll be trying to find a metal bar to extend the current bar and then use the torque wrench to tighten it only
- Julesholling
Ok so that bolt is on seriously tight, can't shift the bloody thing at all. Left it soaking in WD-40 overnight to see if that helps.
One other question that suddenly popped into my head was is that bolt a reverse left hand thread? Can't see why it would be as it's not under any rotational force that could undo it but wanted to double check........
Just to clarify it's the rear pinch bolt that needs to be undone to adjust the chain.
Yea the rear pinch bolt to the right of the chain, it should have a metal clip which holds the brake pipe in place, loosen it then rotate the hub adjuster away from you to tighten the chain (it doesnt need to move much at all to tighten) its a normal thread so lefty loosey
(pushing the bar away from you towards the wheel) get a breaker bar on it, someones probably used one to tighten it up
- Julesholling
Right got the **** thing off. I found that a breaker bar and lots of swearing helped
Swearing works for me too... as does grunting like an old man..lolJulesholling wrote:Right got the **** thing off. I found that a breaker bar and lots of swearing helped
