genesis headrace bearings
martynfzr
hello can anyone tell me if the genesis use's the same hearace bearings as the later fzr's
cheers martyn
cheers martyn
Re: genesis headrace bearings
If you take the top yoke off you might be able to see the bearing number which should tell you (or a bearing supplier) which ones you have. If you still can't see the code you'll need to undo the tensioner and locking rings with a C-spanner. If you don't have a c-spanner get one before you start.
TBH most Yamaha's are the same but I can't say for certain. Course you could have a look on Wemoto
- Motorcycle Solutions
Martin head race bearings all the same for fzr400/r through to fzr600/ r
I supply the right ones and £25 plus postage £2.50
If you want a set i am ordering some tommorrow for a 3en2 shaft.
