Throttle cable run on NC35
Posted: Fri Jul 24, 2009 11:14 am
by Drunkn Munky
Whats the standard run of the throttle cables on a NC35? mine run below the yoke but i feel there getting in the way of the air flow to the tray, ive tried running them above the yoke but the throttle tends to stick when going from lock to lock. Has anyone managed to run the cables above the yoke without problems? Doubt it'll make the slightess difference to the airflow but it'll make me happy
Re: Throttle cable run on NC35
Posted: Sat Jul 25, 2009 7:36 pm
by Speedy
Over the bottom yoke and under the clocks frame. Mine's always been like that with no issues at all!
Someone else asked a similar question quite some time ago, so I got the photo below sorted for him; it may help you further too.
Posted: Sun Jul 26, 2009 3:51 pm
by Drunkn Munky
Cheers speedy that helps a lot. maybe i just need to lube the throttle cable. My clutch cable is also run different than yours so i'll fix that.
