Page 1 of 2
nc29 shock length
Posted: Thu Jul 23, 2009 12:33 pm
by silver
Hello!
Does anyone know the length of the rear shock of nc29? Cbr 600 f(2001 model) shock length is 310mm,could this fit?
http://cgi.ebay.co.uk/HONDA-CBR600-CBR- ... 2|294%3A50" onclick="window.open(this.href);return false;
Re: nc29 shock length
Posted: Thu Jul 23, 2009 3:44 pm
by PARUS
NC29 eye to eye length - 285-290mm
310mm will fit as for my experience.
Posted: Sat Jul 25, 2009 7:58 pm
by missinNZ
silver, the problems you will encounter with a 600 shock,
- yep its 310mm and old one is 290mm
- increased angle will mean removing the coolant bottle as new one hits it and you cant get enough clearance to fit lower eye of shock into place.
- you need to dremal grind out the link to even make it fit (and be able to move adjust)
- check the eye bolt size as i had to have bushings made up to bulk it out to male tight (10mm out to 12mm if i recall)
- the big one is the increased angle of swingarm will drop your chain down, you ll have to lose some fairing.
- balancing your wheel is tricky as chain is very loose and until weighted you cannot tell if you have 1 inch play
- as above the increased angle will drop chain angle down onto the swingarm gaurd (small plastic runner/slide above left heel guard) and wear it faster and also shin up one side of your chain.
- dependant on what shock you have you also may have to grind off some of the top eye to make it fit into the gap
i have put a 02 600rr shock in my bike but from all the above drama im looking at taking out..............?
Posted: Sat Jul 25, 2009 8:00 pm
by missinNZ
even reading the post again im going to get neg response to my post, mine is the same eye to eye i know 600f can fit im just highlighting the difficulties ive had.
Posted: Sat Jul 25, 2009 9:49 pm
by scratchin
i have the exact same shock on both my bikes fits straight in only mod needed is to dremel a small amount out of the dog leg for the ajustment screw works brilliantly and a massive improvment over the stock shock
Posted: Mon Jul 27, 2009 9:10 pm
by gtlover
Yeah, I've got the same shock, which works nicely with my weight, but I want to bring the back end back down to where it ought to be. Still, it's probably the way to go for a cheap racing mod.
Posted: Tue Feb 16, 2010 2:12 pm
by zul_cbr
Hi..
i'm a bit curious...i just replace my stock rear shock with a 600 shock (don't know which model).
a quick search on this site, mostly said that changing to 600 shock will raise the rear end a bit and different lean angle when parked. but, why it isn't happen to me ?
Posted: Tue Feb 16, 2010 4:16 pm
by PARUS
I think because the shock it the same length :))) But bike looks well.... in any cases..
Posted: Tue Feb 16, 2010 5:14 pm
by racesupplies
I think the CBR600 shock you need is the FS,not sure but that was what I was told was on my bike when I bought it.
Posted: Tue Feb 16, 2010 5:29 pm
by yeurman
Hi, I run both WP (dry) and Ohlins (wet) rear shocks and I have them both set to 305mm. puts more weight on the front, but it suits me and both bikes handle very well.
Col
