aero dynamic modification to rear end
Lope
Post by Lope »
I've heard of people making movable brackets to get aerodynamic benefits on the track, anyone know about this?
mattydrvf
Bike owned: Rvf baby
Re: aero dynamic modification to rear end :)
Post by mattydrvf »
When you say areodynamic do you mean hiding number plate from fuzz... lol
With your nuts and bolts try using a washer and then a spring washer. The spring washer keeps tension on the nut so it wont undo and with the normal washer should allow you to move it fairly easily.
With "a windy bit" why dont you think about using a servo out of an rc car or summit. then you could operate it with the flick of a switch.... :up:
Lope
Post by Lope »
hehe bro, well some might use it for that on the road, but a lot of people are interested in every benefit they can get on the track.
The Hamster
Post by The Hamster »
Aerodynamic improvement on the track????
So surely fitting this contraption, and the time and effor tgone into doing so, was that much easier than removing the numberplate when on the track seeing as this would actually give better aerodynamics??
LOL I cant get my head around this one other than it bieng used purely to get away form chasing people.
Lope
Post by Lope »
A lot of systems seem complicated...
Spike16
Post by Spike16 »
removing the plate would also reduce weight
like the idea of servo operated tho, but Id be more interested with a quick release tail tidy that was a block connector to the indies built in so the whole number plate and indies come away in 1 quickly
Saveris
Bike owned: sc57, nc30
Post by Saveris »
my solution for this problem is simple. usually it takes 24 seconds to mont/ unmount:
on the road:
on the track:
simmo
Bike owned: nc30 road & zxr400 race
Post by simmo »
love it saveris :up:
