NC23 not soo felling horny------------horn stoped working
the horn on my nc23 has stopped working
what could it be ??
what could it be ??
- w00dzy
Re: NC23 not soo felling horny------------horn stoped working
the wiring possibly.. maybe the switch?
try wiring another horn to it..
thanks i should of said i've tried a new horn and that still doesn't workw00dzy wrote:the wiring possibly.. maybe the switch?
- w00dzy
I would guess its probably the switch.. and it might be worth taking it apart.. may be that a wire has come looose?
Mine had same problem but rear lights also didn't work (side lights) problem was found to be the earth wire on the connector on the top fairing. The horn should have I think light green & green/stirpe cables, if you've got access to a multimeter, set to dc volts range and put across the 2 wires and press the button on the horn, should be voltage, if not then you can check the earth connection to the bike, set meter to ohms or contiunity test (buzz when u tough the 2 leads) test between (I think it's the light green) and any metal work on the bike and it should buzz. The connectors on the top fairing bracket I've found are very prone to breaks in the connetions so might just be worth having a good look. Failing that it could be the switch, but I'm an electrician by tade and into alarms and cctv now & I went through a few switches lol before I found the black/brown stripe was split and providing the earth connection for the horn and rear lights etc lol
mavrick_001 wrote:Mine had same problem but rear lights also didn't work (side lights) problem was found to be the earth wire on the connector on the top fairing. The horn should have I think light green & green/stirpe cables, if you've got access to a multimeter, set to dc volts range and put across the 2 wires and press the button on the horn, should be voltage, if not then you can check the earth connection to the bike, set meter to ohms or contiunity test (buzz when u tough the 2 leads) test between (I think it's the light green) and any metal work on the bike and it should buzz. The connectors on the top fairing bracket I've found are very prone to breaks in the connetions so might just be worth having a good look. Failing that it could be the switch, but I'm an electrician by tade and into alarms and cctv now & I went through a few switches lol before I found the black/brown stripe was split and providing the earth connection for the horn and rear lights etc lol
thanks i'll have a look at that and let you know what i fined
thanks for your halp evryone
i got my horn fixed to day heres what was wrong with it
the switchgear was full of water and the fuse was blown but that didn't blow till after i cleaned the horn switch
it also blow the head light out but replacing the 15amp fuse fixed that
