Can't switch 1st gear\Neutral ??
Posted: Thu Jul 16, 2009 11:57 am
by PARUS
Guys,
Need you advice, I can't switch to 1st gear and find neutral. What can be the issue? Looks it yesterday after car-washing facility
Re: Can't switch 1st gear\Neutral ??
Posted: Thu Jul 16, 2009 1:19 pm
by leopard_pagan
damaged gear selector fork inside gear box
Posted: Thu Jul 16, 2009 1:57 pm
by PARUS
leopard_pagan wrote:damaged gear selector fork inside gear box
Cool. As I see in this case I need to split the engine. Correct ?
Posted: Fri Jul 17, 2009 7:02 am
by leopard_pagan
what ever is needed to get to the gear box.
if the gear selector fork is bent/damaged, it displays the similar symptom as you describe + some bikes jump out of gear
it can do this in any gear or all gears.
Re: Can't switch 1st gear\Neutral ?? *Solved
Posted: Tue Jul 21, 2009 8:56 am
by PARUS
Guys
Thanks for you help. Problem was in rearset adjustable. Gear works like Switzerland clock :))))
