My NC30 Dyno Results.
Posted: Tue Jul 14, 2009 5:47 pm
Ok guys here it is, the Results of my recent Dyno Time!
I first thought I had a problem with my Carburettors and simply could not sort it out myself after 6 times having the carburettors off and adjusting this and that!!! I also determined that I did not have the correct tools to accurately set them up and so i had to take it to a specialist.
In came Kevin at Projex in Cradley Heath. Few emails and telephone conversation and my bike was booked in to be fully set-up using the Dyno Machine.
We did a first run to try and find out what the problem might be... It turned out it was an electrical fault to do with the de-restrictor Module under the Speedometer. With that then sorted we did a first full power run to see what we were dealing with.
The red line on the graph shows this first run. It was clear that the Carburettors were unbalanced and the fuelling was all over the place. So we removed the carbs and investigated. After checking the spark plugs, we thought it might be necassary to increase the jets by one size. Going from 116F/118R to 118F/120R. (Completely Factory Standard Bike). We checked the float hieghts and found the Rears to be almost perfect and not needing adjusting, and the fronts were not only too low, but were also out of balance form each other which doesnt help. We reset all the float hieghts to Factory Standard 6.8mm. I also asked if the bike could be made to pick up quicker and have better response, and Kevin suggested the 2.5mm Vacuum hole mod on the slides which I had already done by this point.
With all that done and the bike rebuilt we put it back on the Dyno and performed another Full power Run. the blue line is the result of this second run!
You can see just how much smoother the power delivery is! And how consistent it is aswell. the difference is unbelievable! And the response is incredible! A completely different bike than what i took up there thats for sure.
As you can tell from the graph, almost 90% of the time the bike is producing and holding a lot more power through the rev range. the flat spot is no longer there, just a ballistic amount of power instead! Overall I am really happy with the result. (Im just a little bit annoyed a tthe Peka power output, but the bike is 15 years old now, so i will forgive it. LOL
Although the graph is showing peak power output to be 45.26bhp and 45.65bhp AT THE WHEEL, the second run actually produced an extra 1.8% on top of that due to the differenc ein air pressure in the Dyno Room between the two tests. So peak power on the second run is actually 46.47bhp. (AT THE WHEEL) Not a bad increase just by setting the Carbs up properly wouldnt you say?
Sorry about the Missing bits of the Graph, My scanner is seriously playing up and that is the best i could get it to scan after an hour of trying. LOL
