Rear caliper problems (NC30)
emto
I went to overhaul the caliper and replace my rear pads but the little blank plug which you have have to take off & which covers the access to remove the pin won't budge. I soaked it in WD and penetrating oil and still no luck. It dosen't appear to serve any real purpose so was going to drill it out. Any suggestions??
Re: Rear caliper problems (NC30)
Impact driver..
- paul nc 24
- Bike owned: 2000 R1
And use a little copper grease on the plugs when you rebuild that way it will not be a problem next time.CMSMJ1 wrote:Impact driver..
