Piston Rings
sharpey
Piston Rings
Right i have solved the problem of getting piston rings for my 1wg 3en1 with taggy's help i must add. if you need rings for 1wg's then the 3tj set which you can still get from yamaha unlike the 1's for the 1wg will fit. Me an taggy have cross referenced all the measurments for 1wg and 3tj bores,pistons and rings and all marry up.
I should hopefully have a built and working engine in the next week.
Thanks TAGGY
p.s i was so pleased when i just found out i nearly had to
lmao
Thanks TAGGY
buzzawak
Re: Piston Rings
Hi Sharpey,
Can you post the numbers?
4StrokePete
- Bike owned: FZR400RR SP
Re: Piston Rings
3TJ Std rings 3TJ-11610-00buzzawak wrote:Hi Sharpey,
