Sprocket Bolt
Posted: Thu May 01, 2008 5:36 am
by howl
Hi Just wondering if the front sprocket bolt has a an anti clockwise thread before I put a big breaker bar on it ,as it is bleeding tight . Cheers
Re: Sprocket Bolt
Posted: Thu May 01, 2008 6:16 am
by Cammo
It's normal (RH) thread.
Re: Sprocket Bolt
Posted: Thu May 01, 2008 9:19 am
by mick.mh2racing
Yeah it is a normal thread but think on it'll work tighter over the life of the chain. Lock the wheel and get a big f*** off bar and it'll eventually give. WD40 and rock it a bit and will give up the ghost in the end.
Re: Sprocket Bolt
Posted: Thu May 01, 2008 9:29 am
by thefatman
It took 8ft of scaffold pole to get mine off, and two people holding down the back of the bike so they can be fairly tight.
Re: Sprocket Bolt
Posted: Thu May 01, 2008 9:41 am
by viper_biker
Also, when you re-fit the nut make sure it's to the correct torque setting. I had my bolt work itself loose recently and it eventually broke the sprocket cover housing with the strees it put it under,
Re: Sprocket Bolt
Posted: Fri May 02, 2008 2:17 pm
by howl
Hi Chaps
Thanks for that ,I kind of knew that it was a std thread but as it is going to take a fair bit of undoing, I just thought I'd ask. :D
