Are Thundercat carbs same as FZR600R foxeye
plodder
Thining about buying a set of thundercat carbs to go on my hybrid but are they the same size? Pictures seem to indicate thay they look the same but thought I would check first.
KIYOSHI
Re: Are Thundercat carbs same as FZR600R foxeye
The thundercat carbs have throttle position sensors if that helps.
I think the throttle sensor and the velocity stacks are the only real difference
smemly
- Bike owned: FZR400RR 600 Hybrid
i've got a set in my garage and my hybrid is stripped down for the valve check. I'll let you know if they fit and what the differences are.
plodder
Have bought a set (just waiting for the seller to send them). I'll see if the're any good and try the #38 pilot jets in my FZR carbs too.
