gsxr400 problem
chappymen
gsxr400 problem
Post by chappymen »
hello guys,
newbie her im having problem with gsxr400 1986 model, the problem after starting and idling it
for 2 or 3 minutes the bike die, try to start it again bike wont start! then pulled plug to check for
the spart no spark at plug...is this a cdi failure? hope someone help me with this...tia
summitdog
Re: gsxr400 problem
Post by summitdog »
It could be the CDI or your coils. Does it start again when the bike is cold? Are you creating a ground for the plug when you are looking for a spark?
Scotty
chappymen
Re: gsxr400 problem
Post by chappymen »
hi scotty, yes the bike start when its already cold! i put ground wire on each spark plug to check for spark...Jun
Gavsta
Re: gsxr400 problem
Post by Gavsta »
Check your float bowls.
If there isnt a fast enough draw of fuel then youll get the problems you describe.
