1986 FZR400 GENESIS LEFT HANDLEBAR NEEDED
Posted: Thu Jun 25, 2009 6:54 pm
by Q007
This bar has a bolt that goes into it through the clip on clamp, think this is the only model they ever used these bars on, I currently have 1 fitted but appears to be slightly bent as turning left the bar almost touches the tank but turning right is about an inch away. I personally hadn't noticed :oops: but a m8 of mine had a go on me bike n says it felt off balance to him n disdcovered the slightly bent handlebar.
so if you've got a spare n it's straight :pray: pm me with a price,
Cheers Q.
Re: 1986 FZR400 GENESIS LEFT HANDLEBAR NEEDED
Posted: Thu Jun 25, 2009 11:17 pm
by Evilchicken0
FZ600's had the same bars
Posted: Sat Jul 25, 2009 1:42 am
by dancon3105
Very late reply, but do you still have a locating pin/dowel? (from the bar block to the top yoke) - steel rolled pin into alloy
Mine has an oval hole from wear & tear - but should actually make the bars align (reasonably) evenly
Posted: Sun Jul 26, 2009 2:49 pm
by Q007
dancon3105 wrote:Very late reply, but do you still have a locating pin/dowel? (from the bar block to the top yoke) - steel rolled pin into alloy
CHEERS FOR THAT... :worthy:
Pin removed and realigned.
Q.
