1986 FZR400 GENESIS LEFT HANDLEBAR NEEDED
Q007
Bike owned: FZR 400 1wg 1986 FZR 600r 1995
Post by Q007 »
This bar has a bolt that goes into it through the clip on clamp, think this is the only model they ever used these bars on, I currently have 1 fitted but appears to be slightly bent as turning left the bar almost touches the tank but turning right is about an inch away. I personally hadn't noticed :oops: but a m8 of mine had a go on me bike n says it felt off balance to him n disdcovered the slightly bent handlebar.
so if you've got a spare n it's straight :pray: pm me with a price,
Cheers Q.
Re: 1986 FZR400 GENESIS LEFT HANDLEBAR NEEDED
Post by Evilchicken0 »
FZ600's had the same bars
dancon3105
Bike owned: FZR400 1WG
Post by dancon3105 »
Very late reply, but do you still have a locating pin/dowel? (from the bar block to the top yoke) - steel rolled pin into alloy
Mine has an oval hole from wear & tear - but should actually make the bars align (reasonably) evenly
Q007
Post by Q007 »
dancon3105 wrote:Very late reply, but do you still have a locating pin/dowel? (from the bar block to the top yoke) - steel rolled pin into alloy
CHEERS FOR THAT... :worthy:
Pin removed and realigned.
Q.
