SP2 Brake Calipers - Should I match the master cylinder
RichardB
Post by RichardB »
My Son has a RVF that came with Honda SP2 front calipers fitted. Would it be advisable to fit the matching master cylinder ?
Does anyone know if the 929/954 Fireblade has the same master cylinders as the SP2
Many thanks
Re: SP2 Brake Calipers - Should I match the master cylinder
yes and yes.
The std m/c will be squidgy and feels horrible..
I used CBR600FX calipers and a 1999 blade m/c on mine
RichardB
Post by RichardB »
Thank you for the advice, will start looking on eBay !!
Micro Monkey
Bike owned: CG125, RVF400, YZF1000SP, 996
Post by Micro Monkey »
The radial master cylinders of a 2004 r1 and r6 and onwards works very well also as it is 16mm so is a good match for sp1/2 calipers. Its what i run and the brakes are superb, very strong but progressive.
