NEED HELP!! Routing throttle cables nc30 PROJECT .
Moore
Post by Moore »
:?: CAN ANYBODY PLEASE TELL ME THE BEST ROUTE FOR CABLES,, SHOULD THEY RUN UNDER OR OVER THE INSTRUMENT/LIGHTING BRACKET?
DO THEY RUN BETWEEN THE LEFT FORK LEG AND TOP BOTTOM YOKE?
I HAVE TRYED A COUPLE OF DIFFERENT ROUTES, EITHER WAY JUST SEEMS TO PUT ALOT OF STRAIN THE CABLES WHEN I TURN BARS TO THE RIGHT..
OR SHOULD I JUST RUN THEM BEHIND FORKS AND UNDER THE HEADSET OF THE FRAME!!!! :idea:
tanuki
Re: NEED HELP!! Routing throttle cables nc30 PROJECT .
Post by tanuki »
No need to shout... :scare:
I'll move this thread to the V4 worship for you.
The Hamster
Post by The Hamster »
http://akhara.com/nc30/nc30manuals/VFR4 ... 0R_C01.pdf" onclick="window.open(this.href);return false;
Try looking on page 25 on this link.
Might not help that much, but its worth a try.
The cables are pretty much routed like you say, between the upper and lower yokes, and under the instrument bracket.
play around a bit as you need to have one cable outside the other, and not overlapping in any way. it is fiddly, but youll ge tthere in the end.
Moore
Post by Moore »
Hahaha!!! sorry for shouting..
thanks for your responce and thanks for links... ile check em out!!
i had sevral atempts at fitting them earlyier,, each time i thought id cracked it..
But i give it up the last time as i had to rev it backwards!!!
CHOW FOR NOW :oops:
