Page 1 of 2
NC29 rear shock jack up kit?
Posted: Tue Jun 16, 2009 8:05 pm
by domski
What's the method for jacking up the rear of an NC29?
Re: NC29 rear shock jack up kit?
Posted: Tue Jun 16, 2009 8:15 pm
by chrisja2
Fitting a cbr600 shock or similar?
Posted: Tue Jun 16, 2009 8:20 pm
by domski
Done that. Fitted a CBR600F2 shock, as per the advice on here and it's the same length at the stock shock right?
It's needs 20mm-50mm more height I'd say.
Posted: Tue Jun 16, 2009 8:53 pm
by scratchin
are you sure you got the right shock the standard shock is 290mm eye to eye the 600 shock is 310mm eye to eye and it lifts the rear more than 20 mm
Posted: Tue Jun 16, 2009 9:15 pm
by domski
That's what my shock looks like yeah...
...from a CBR600 FV model.
Bugger :(
Posted: Tue Jun 16, 2009 9:38 pm
by scratchin
check the eye to eye measurment, the shock might be goosed and measures ok but drops low with the weight of the bike, mine came off an 02 bike and was in really good condition
Posted: Tue Jun 16, 2009 9:43 pm
by domski
I've just had it serviced at a cost of £100!
So is there no other way of adjusting the ride height other than buying a pukka race shock with that adjustment built in?
Posted: Tue Jun 16, 2009 10:13 pm
by scratchin
are you still using the original dog leg?
Posted: Tue Jun 16, 2009 10:17 pm
by domski
All the linkage is stock NC29.
All I have changed is the shock itself.
Posted: Tue Jun 16, 2009 10:23 pm
by scratchin
only way i can think is if you can get a shorter dog leg which will raise the arse end up
