Hybrid airbox
Hybrid airbox
Ok guys after Snetterton I have decided pod filters are not the way forward with the 600 conversion. (mostly after it rained big time)
Hence I am making an airbox based on the BDK kit airbox, however it will have an intake at the rear (that can be modified to use the 2 side inlets as ram air). This is to my own design and bolts below the inlet rubbers (as per zxr400 kit airbox) and uses the inside of of the tank as the top and seals between the frame and top of tank as per bdk kit airbox.
As one of the forefarthers of the 600 conversion I think I owe it to everybody that once i get it working and set up on the dyno, that I should start producing them for other modders. I will be playing around slightly with intake sizes as well as jetting so hoping to get it spot on.
Steve
Steve
Re: Hybrid airbox
Your a very nice man :)
