NC30 Sheared engine mount bolt... Advice?
Posted: Fri Jun 12, 2009 9:41 pm
Looking for a bit of advice again guys... Finally got round to dropping the engine out of the bike today (NC30) and things were going well until I loosened the top left(as you sit on it) engine mount bolt. Thought the bolt was shifting then it sheared!!
Not too much of a problem tho I thought... Simply drill into it which I did and then screw in a stud extractor from the shiny set I got for Xmas... Again just when you think you've got it sorted the F***i*g stud extractor snaps in the hole! I've been through half a dozen drill bits and nothing is looking at drilling the stud extractor. Any advice on drill bits to look at this stuff or is it a job for an engineers workshop?
Had to walk away from it tonight... maybe a fresh set of eyes in the morning will help but any thoughts would be good...
Also while I'm on what size socket are the spark plugs? Had a 10mm socket another bike but didn't seem to fit? Is it a honda only item or will the right off the shelf plug key do the job?
Cheers guys in advance... Excuse me while I get a beer (or two)from the fridge!!
P.S. the one thing I did learn today is that Silverline Stud extractors are crap.... but very very hard to drill!
