Advice on track 3EN1 requested
Posted: Fri Jun 05, 2009 1:45 pm
Hi all,
I am new on here looking for info on 3EN1 model. I have just bought one in bits from e bay and have already learnt a few things from lurking on here. I have already bought it a 2007 R6 shock (red spring) and blue spot calipers (hope they fit!)
The bike is intended as a cheap project for short circuit trackdays. I am not planning any road use. The bike is mostly standard and complete and I aim to spend the next week or so getting it running and on the dyno. What bhp should I expect if engine is healthy?
The bike has a race end can (no baffle) so I will be fitting a dynojet kit if not done already. Am I likely to need a db killer? (most tracks I ride are 102 /105db) Or is the bike unlikely to be that loud?
What brake pads are recommended for blue spots with standard discs for track use?
With standard front forks, what springs, oil weight and quantity are recommended for track?
Does anyone know standard chain pitch and front / rear sprocket sizes? Usually with track bikes I drop one tooth from front and add one to three to rear. Does this work with FZR400 or does it cost too much top end?
Do I need specific track bodywork for 3EN1 model or will others (FZR600, R6, later FZR400) fit with simple modification? (the simpler the better!) Does anyone have any they want to sell?
Does anyone do (pref adjustable) clips ons for these bikes, or is it possible to shim Harris or similar to fit
Are Bridgestone 090 / Dunlop Alpha 10 still the best, or only choice, for 17" fr /18" rear wheels?
Maybe next winter I will try swapping the swing arm to get a 17 inch rear in order to run Supercorsa's. Given that I am a mechanical numpty which is the easiest conversion and what parts do I need?
Grateful for any opinions you can offer. I live in maidstone, so recommendations for any local engineers / sprayers / miracle workers would also be welcome.
