clock colour change
				Mr_Fen
Re: clock colour change
yes i have more sets available.
				scotjell
- Bike owned: VFR400 NC30x2
Just fitted the new clocks and the temp gauge one when powered up went half way up the gauge. Apart from taking apart again any tips on setting up??
Have you disturbed the earth? Usually if you take the earth off the temp gauage it goes to 'hot'scotjell wrote:Just fitted the new clocks and the temp gauge one when powered up went half way up the gauge. Apart from taking apart again any tips on setting up??
				scotjell
Of course as had to remove the three cables to get the gauge out of the surround to remove the bezel. So when switched on now after replacing it all it goes to half way and when warmed up just under the red.
				big cheese
- Bike owned: VFR NC30 DUCATI 748
hi
MR FEN do you have any clock faces left would like to buy a set if any left,
thanks
thanks
				VfRTeddy
- Bike owned: Vfr400 nc24
Mr Fen how much would i be able to have the damaged dials for? me being a lazy bastard an all, an them actually not lookin that bad
Ben
Ben
				Adrian89
- Bike owned: NC23 and '05 Blade
Do the clock lights shine through the new faces? or does the light that lights up what speed you are doing at night come from round the edges?
I have a damaged set of clocks so could take mine apart, spray the faces white then stick a black transfer kit on to get the same effect as these kits give, or alternatively CNC cut some new faces out of plastic and stick a transfer kit to that but Im concerned the speed, temperature and revs wont show up at night?
Basically what are the faces made from? solid white plastic or some sort of semi transparent material?
Adrian
Adrian
				scotjell
They are semi transparent and give a nice warm glow!!!
				buffalobisonhead
Hello There,
I would be interested in a MPH speedo face for my NC35, if anyone has any ideas would love to hear them.
				Claytonbojo
- Bike owned: VFR NC30 NSR125, Pit bike 200C
can any one tell me or Mr_Fen that the clocks u have dow they glow or change coloure in anyway when the light is ont? Thanks Clayton
