How to fit the 600 into the 3tj
rrsp
- Bike owned: fzr600-,yzf750-,owo1,750
Re: How to fit the 600 into the 3tj
looks like theres a thundercat on it's way then,cheers for that very handy
rrsp
You probably need to cut them, the R^ was a redesigned engine from the T'Cat. I'd expect the R6 to be shorter stroke and wider pistons which would alter the bore spacing and therefore the exhaust centres.
Have a look at the FZ6 against the earlier fazer and you'll see what I mean
nick
Hmm.....thought as much Boris....
Whats going to be the best ones to look out for, T-cat or any of the FZR600 models? I know theres the Delkevic headers and sandybikespares ones, but i'm not 'flushed' enough to get a new set so its 2nd hand for me
bendy3
- Bike owned: FZR400RRSP FZR400 HYBRID RRSP
Ive got some 4JH headers moded for a 3TJ with 2" stainless outlet up for grabs. Will get some photo's up soon.
nick
Sweet, how much?bendy3 wrote:Ive got some 4JH headers moded for a 3TJ with 2" stainless outlet up for grabs. Will get some photo's up soon.
Shirley Nick wants an unmodded set to use with a 4JH engine ???
ThunderCat or FZR600R Foxeye will fit
nick
Hey, easy tiger, i may be in touch with my feminine side but calling me Shirley is just a bit much........LOL!!!Evilchicken0 wrote:Shirley Nick
Ta for thatEvilchicken0 wrote:.....ThunderCat or FZR600R Foxeye will fit
nick
Here we go again....this time its an electrical question
I'm still trying to decide on how best to wire up my (eventual) 3TJ/Cat hybrid. I'm really lost in minefield of thoughts over what combination of loom/ecu to use. I've got cat carbs but i assume that i could just leave the tps unconnected if i decide to go with a non cat ecu?
My main area of thought is over all the other bits that go with the loom, like the ignition switch, coils, reg/rec, starter relay etc..... As its a track only bike i'm not bothered about lights or indicators so the relays and stuff that go with those is surplus to requirements.
So, if i decide to stick with the 400 loom and plumb in a 4JH/Cat ecu how much of the other electrical components from the 400 can i stick with such as the reg/rec, starter relay. I know 600 coils are a must i'm just not sure about the rest.
I'd like to get a Cat loom and ecu but then will i need the reg/rec, starter relay, ignition switch blah blah blah....from the cat as well?
HELP!!!!!!!!!!!
HELP!!!!!!!!!!!
