Page 8 of 9
Re: New bike
Posted: Fri Sep 26, 2008 4:07 pm
by spooky
Neosophist wrote:
I have these in my bedroom, the boot of the motor's got a couple of NC24 exhaust systems in there and dont' get me started on the bits of the 35 :D
What are you doing with the two nc24 exhausts
Nio
Re: New bike
Posted: Fri Sep 26, 2008 7:29 pm
There spares :)
If your afterone try ebay..
NC21 full system
NC24 Full system
Re: New bike
Posted: Sat Sep 27, 2008 10:03 pm
by fastdruid
Been busy today, cleaned the carbs and adjusted the float heights, 3/4 were wrong.
They were pretty good inside, apart from the float heights anyway, this is before I started cleaning!
Tiny touch of dust in the very bottom of the bowls.
Then time to fix the wiring from removing the alarm, bit of soldering then wrap up with some decent[1] electrical tape
Then a bit of cleaning, with the heat shield removed the rear pipe is a bit ugly!
A bit better now (and the fork shroud cleaned too)
Also polished the exhaust and heat shield on the LHS
I went on a bit of a polishing mission, did the silencer and pillion brackets too.
I took off the subframe to fix the wiring properly, I've cleaned it up and as soon as I've cleaned up the mudguard I'll refit it.
Druid
[1] IMO not worth buying cheap electrical tape as it either doesn't stick or dies with in a short while.
Re: New bike
Posted: Sat Sep 27, 2008 10:20 pm
by fastdruid
Forgot to say, I was very glad to find that it hadn't been rejetted for the restriction kit either.
Druid
Re: New bike
Posted: Mon Sep 29, 2008 1:56 am
by spooky
missed them. too late again.
Re: New bike
Posted: Sat Nov 01, 2008 8:16 pm
by fastdruid
Been a bit pre-occupied recently so no movement until today.
Thought it was about time I did some stuff though so swapped the front sparkplugs for the new ones (I'd already done the back ones). I test fitted the hugger, cut down the two screen bolts that fouled the air tubes, removed the old mudguard and test fitted the new one, removed the brake lines and calipers and tried to refit the rear brake caliper.
Run into a stumbling block though, the HEL line has the wrong type of thread on the caliper end. Bugger.
Druid
Re: New bike
Posted: Sat Nov 01, 2008 10:28 pm
by fastdruid
Some pictures.
Swapped the bar weights off NC35#1.
New mudguard
The air tubes (this was actually before I cut down the screen bolts, you can see the one that is too long)
The hugger, braided line (got to be swapped though) and cleaned up hanger.
Still missing the silencer though, what will be fitted.....
I'm thinking carbon fibre! :D
Druid
Re: New bike
Posted: Sun Nov 02, 2008 10:26 am
Ooh its gettin there, is the bike in the kitchen? I'm after some black tiny pop-rivets for my screen atm
Re: New bike
Posted: Sun Nov 02, 2008 11:53 am
by fastdruid
Neosophist wrote:Ooh its gettin there, is the bike in the kitchen?
Yep, garage is external, has no power and full of other bikes, nothing like working in the warm comfort of the kitchen! :D
Getting it out will be a bit tricky, just need a few mates round to help out.
Druid
Re: New bike
Posted: Wed Nov 05, 2008 8:51 pm
by RVFHooligan
Hey Druid, I noticed in this pic that you left the lower air box attached to the carbs. Is that a common trick to avoid the hassle of lining it back up again on the carbs? The reason I ask is because when I assembled mine 3 out of the 4 carbs lined up perfect but one was a pain in the ass to get lined up. I'm going to leave it attached this time around because I don't want to have to fight it again.
